ROUTER FIRMWARE UPDATE
Message 3 of 3
New to talktalk. Testing says my router needs a software  update baut gives no idea where to download from!!
Message 1 of 3
Hi davros19461
I've checked but I'm unable to connect to your router.
Which router are you using? (make and model)
Message 2 of 3
TalkTalk controls all firmware updates. If you have only just connected the router, it will probably update itself overnight.
What make/model of router do you have & what firmware is it currently running. This is often quoted at the bottom of the login page to its UI.
