on 06-03-2019 12:36 PM
Hello. I've got the Sagem F5364 but it's been unplugged for a while due to using a 3rd party router. I'm now using it again and wanted to check it had the latest firmware version installed. How can I check this?
12-03-2019 03:46 PM - edited 12-03-2019 03:54 PM
Hi @Shaneee
Interesting. The Wi-Fi Hub is normally set to communicate with the update server every 3 days to see if an update is available.
I'll alert the TalkTalk team to take a look see and try to push an update to the Hub.
...and I see that Debbie has speedily replied.
Like below to appreciate my help . . . Mark as solved Accept as Solution
on 12-03-2019 03:43 PM
Hi Shaneee
This has the latest firmware version.
on 12-03-2019 03:30 PM
The version it's on is SG4K10001400t
TR-069 settings have not been changed. Thanks for the reply.
on 06-03-2019 01:12 PM
Hi @Shaneee
Call up the router admin page here.
Bottom of the sign in page you'll see the version. SG4K10001E00t is current.
If you leave the Wi-Fi Hub powered and connected then by the end of the week, assuming you've left the TR-069 Client switched on - both Enable and Inform with default settings - then the software should be updated automatically.
