Router Help needed
TimTim2021
Message 12 of 12
Thanks for everyone in the community offering help.
My in-laws router needs replacing. They have been with TalkTalk years and years and in that time they have had a new TV set-top box sent to them but they still have the original router which is now cutting out all the time. It needs replacing ASAP. Please help
11 REPLIES 11
Message 1 of 12
Hi TimTim2021
Ahh thank you for your kind words 🙂
Please connect the router when it arrives but leave the powerlines in for the TV box.
Let us know how you get on.
Thanks again
Debbie 🙂
TimTim2021
Message 2 of 12
Yes they are. As its an old house the telephone point is in their hall so the router is in there and the tv set top box is in the living room next to that. Hopefully the wifi on the new router will be sufficient.
Thanks again for all your help, I have previously not had the best experiences from TalkTalk customer services but you have been wonderful.
Message 3 of 12
Hi TimTim2021
Are the powerlines being used to connect the TV box?
The wireless should be better on the new router so you may not need them now.
TimTim2021
Message 4 of 12
Oh ok Debbie. Can I check with you would they even be required now? My in-laws have a new(ish) TalkTalk tv set-top box and now thanks to you a new router is on the way to them - will these two just not pair together and work without the need for anything else?
Message 5 of 12
Hi TimTim2021
No sorry, this wouldn't be included with the router. If the powerline adapters are old then they will most likely be out of warranty.
These can be purchased from our online store.
TimTim2021
Message 6 of 12
Hi Debbie,
Those are the ones - yes they are power line adaptors. Those are really old too, their connections where the wire plugs into them is loose. Will two new power line adaptors come with the replacement router?
Message 7 of 12
Hi TimTim2021
You're Welcome 🙂
Is this a power line adapter? Wireless Powerline adapter guide
TimTim2021
Message 8 of 12
Hi Debbie,
Thank you so much for your excellent customer service. The router is in my in-laws hallway at their home. Where the router plugs into the mains electric it has a funny plug that has lights on - there is also one of these plugs, with three lights on, on the power lead of the tv set-top box. I  do not know the technical name for these but will replacement ones (if they are even still needed) come with the new router?
Message 9 of 12
Hi TimTim2021
Thank you for creating a new topic on the Community.
Debbie 🙂
TimTim2021
Message 10 of 12
Thanks Gliwmaeden2 - I have updated my profile, added the TalkTalk account number and my in-laws details so fingers crossed that should be sufficient.
Gliwmaeden2
Message 11 of 12
Please check my reply re completing community forum profile details, @TimTim2021, on the thread where you posted earlier.
This must be done for staff to identify the account etc.
