Router keeps disconnecting and needs to be restarted
Wellfedup
Message 14 of 14
Over the last few weeks my home wifi has constantly been disconnecting from all wireless devices  e.g. mobile phone, tablet, laptop. I get different messages on different devices e.g. mobile phone disconnects and the wifi is not visible, tablet says you need to enter password but when you do it says its incorrect, laptops just says unable to connect to network. Devices connected by ethernet e.g. PC and powerline adapters e.g. smart TV seem unaffected by this issue. Devices that wont connect by wifi can still be connected by ethernet (e.g. laptop). The problem can be resolved temporarily by re-starting the router but as it now only lasts around half an hour before disconnecting again this is unworkable.
Steve
13 REPLIES 13
Message 1 of 14
Hi Wellfedup
Message 2 of 14
Yes please, the one I have is quite old and been having lots of issues with it recently, Thanks, Steve
Steve
Message 3 of 14
Hi @Wellfedup
I'll say it again, please re-read the last two paragraphs of my last post. Nothing you have done yet will fix anything permanently.
Message 4 of 14
Hi Wellfedup
Would you like me to send a different router for testing?
Message 5 of 14
Hi, I can now see the 2.4 GHz band on my Motorola mobile phone and have connected to this. Our other mobile, tablet and laptop can see the 5 GHz band and i have connected them to this. However this hasn't solved the issue around the devices disconnecting and then not being able to reconnect unless i restart the router
Steve
Message 6 of 14
Hi @Wellfedup
Please re-read the last two paragraphs of my last post.
Message 7 of 14
Hi Wellfedup,
If you still can't see the 2.4GHz band can you try rebooting your router and then check again. Please let us know how you get on
Message 8 of 14
Ok thanks, I have amended the name of the 5GHz and can see this one on my tablet, laptop and one mobile (but not another). I cant see the 2.4GHz on any of them
Steve
Message 9 of 14
The HG635 is a dual-band router & offers both the older 2.4GHz & the newer 5GHz Wi-Fi bands. The problem is these are two different networks (SSIDs), but they share the same name, so you can't tell which one you are connected to. Log into the router (http://192.168.1.1) and enter a username of "admin" and use the unique router password (see the label on the rear of the router at the top).
Go to:-
"Customise my wireless network"
Append "5G" to the end of the network name of the "Wireless 5 GHz SSID" field. Then click "Save".
This will not fix your issues, but it will make it much easier to identify the band you are connected to. This way you will know which band is causing your problems.
You may then wonder what was really the point of this if it won't solve the problem? This is because the whole topic is too complex to be dealt with in one post. The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
Message 10 of 14
Hi Kal, I have added my home phone number to my profile
Steve
Message 11 of 14
Hi, the router is called a Super router HG635 with G.1.01 software
Steve
Steve
Message 12 of 14
Hi Wellfedup
Can you please add your home phone number to your 'Community Profile' so I can pick this up for you.
Message 13 of 14
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
