Router needs resetting every day
Pingkej
Message 3 of 3
So I joined a few months ago had no issues but for the last few weeks I'm having to reset my router daily. The wired connections are fine but WiFi devices (phone, laptop, iPad, speakers) are unable to connect on WiFi until I reset the box, then all is brilliant for about 1-2 days.
Rang technical support who were useless and after 40 minutes suggested resetting the box which I agreed would fix the issue but I shouldn't be daily resetting the box.... Any help would be massively appreciated because at the moment I feel like just switching provider
Message 1 of 3
Hi Pingkej
Can you please add your home phone number to your 'Community Profile' so I can pick this up for you.
Skynet_TX
Message 2 of 3
Hi @Pingkej,
What model of router do you have ?
If you have the Sagemcom Wi-Fi Hub then it is possible the 'Wi-Fi optimisation' feature may be causing you problems.
If you are only having issues with wireless devices then you could be suffering from Wi-Fi interference, you could try changing the channels that your router broadcasts the Wi-Fi signal on, you can use free smartphone Apps like this to see what channels are being used within range of your smartphone, you can then change your router to use channels that are less congested.
