Router not accepting Wi-Fi password
My router has suddenly dropped connection on a couple of items and won’t accept the password as being correct when I try and re-connect. Meanwhile other items are connected and working absolutely fine.
Help!
There are two passwords, one for logging in to the router admin at 192.168.1.1 and a different one for the WiFi.
Check carefully !
Martin
Hi JennC
Are you using the wireless password on the router and not the router admin password? (there are 2 stickers on the back of the router)
It may be worth factory resetting the router using the pin hole reset for ten seconds.
