on 23-01-2019 12:49 PM
My services were supposed to go live yesterday, unfortunately did not happen.
Contacted support several times and asked to wait until midnight, no luck. Reset the router dozen times, all the lights are green except Internet - it is red. Connected to the router, I clearly see that my devices are properly connected to the router and the issue is the router not being connected to network. Checked the main socket and all the cables, everything is connected properly and I can clearly see that I do not have assigned IP at all, while the support representatives were trying to convince me that I need to use a different browser or clear the cache, not being able to undertand that the problem is not on Application level but on a Network level. I was also offered engineer's help, ofcourse paid service. Why would I pay for a service that was not provided to me?
I am waiting for your advices. Thanks
E
on 28-01-2019 08:56 AM
Hi ebruilyaz,
Thanks for the PM. I've replied requesting a bit more information
on 25-01-2019 11:19 AM
Hi ebruilyaz,
Our network team are going to log this out to BT Openreach for an engineer visit. if you'd like us to go ahead with the engineer visit can you confirm:
I've also PM you to confirm some other details
25-01-2019 08:58 AM - edited 25-01-2019 09:04 AM
Hi ebruilyaz,
"but tried calling the landline number that I received by talltalk and it is ringing. Wisdom says that if you do not have a phone connected to the line it will not ring."
The line will still ring if there's no phone connected but I do think the most likely cause of the issue is a crossed line
I've raised this to our network team for further investigation, I'll let you know when I receive an update
Our network team are looking into this but if you are thinking of leaving please see this help article
on 24-01-2019 02:26 PM
I was not able to find a landline phone as I am working all day, but tried calling the landline number that I received by talltalk and it is ringing. Wisdom says that if you do not have a phone connected to the line it will not ring. So it means that there is a huge problem as my service is being used by someone else, even though I am the one paying for it and talk talk does not mind that.
As for days I am waiting for a miracle to happen and facing the ignorance of talk talk, please advise me the shortest way to cancel my contract and change for a reliable ISP.
on 24-01-2019 12:55 PM
OK, the line is still showing connected so it looks like you may have a crossed line. Did you manage to get hold of a landline telephone?
on 24-01-2019 12:46 PM
OK thanks, I'll just check the line and get back to you
on 24-01-2019 12:32 PM
on 24-01-2019 10:47 AM
Hi ebruilyaz,
Thanks for posting the photos. could you switch your router off and let us know when you've done this.
on 23-01-2019 11:04 PM - last edited on 23-01-2019 11:10 PM by Gondola
on 23-01-2019 04:50 PM
It is an absolute nightmare that I need to convince my ISP provider that I am not able to connect to network, istead of someone checking the problem properly. Well, I don't know what you see from your end but I am attaching a screenshot from my talktalk account/status check and if needed I will upload one from the router settings as well where you can clearly see that the router is not connecting to Internet (WAN). I will go and buy a phone just to check your service faults. Thanks for making me an expert in networking!
on 23-01-2019 03:30 PM
Hi ebruilyaz,
Thanks for updating your profile
I've checked the number in your profile and it's showing that the router connected to this line is in sync and connected to the internet, and an IP address has been assigned.
There's a possibility that you may have a crossed line which would explain why you can disconnect your router but it shows as connected at our end. Is there any possibility that you can get hold of a telephone to test with, borrow one perhaps? If you are able to get hold of a telephone could you try dialing 17070 and check that the number read back to you is yours (if not then can you make a note of the number)
on 23-01-2019 02:04 PM
I recently updated my profile, you can find my number there. I do not have a phone and I am not able to test the phone.However the problem with my broadband seems to be hopeless as the customer service is trying to convince me that they are able to see my router even when it is unplugged. Not a service type that I would recommend.
E
on 23-01-2019 01:20 PM
Hi ebruilyaz,
I'm sorry to hear this. Do you have a dial tone? Please can you update your forum profile to include your telephone number so that we can look into this further. To do this go into "my settings" then "personal information" then add your details.
Please do not post any personal information on the forum.
