Router not working - no internet!
AlisonWestWemyss
Message 4 of 4
I have a holiday let & my current guests have no internet.
It worked for about 10 minutes once the router was switched off and on today. They told me it hasn’t been working now for a few days.
The socket, wiring etc is fine. There are no devices connected. It’s plugged directly in to the master socket. There’s no phone plugged in/landline in use.
The line test says there are no problems on the line to the router. There are no problems in the area. I am unable to contact anyone at TalkTalk - the live chat function doesn’t appear to be available, I can’t phone either - what can I do to get this fixed for my guests?? It’s clearly an issue with the router…how do I go about getting replacement router from TalkTalk?
3 REPLIES 3
Message 1 of 4
Hi AlisonWestWemyss
Please can you update your Community Profile to include your TalkTalk landline number, we can then look into this for you.
Skynet_TX
Message 2 of 4
Hi @AlisonWestWemyss,
What light(s) are showing on the router ?
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate the faceplate or any of the phone wiring in the property as being a possible cause of the problem.
martswain
Message 3 of 4
@AlisonWestWemyss
It might be the router that is faulty.
It could be a fault with the line, at the fibre cabinet if you are on a FTTC service or at the exchange if on basic ADSL broadband.
Chat is available, along with opening hours from the link below
https://community.talktalk.co.uk/t5/Articles/Our-update-on-Coronavirus/ta-p/2468300
However, they are likely to ask you what the indicator light(s) are showing, if the phone line is working normally and to connect at the test socket with a microfilter to eliminate faceplate and wiring issues.
