15-06-2021 03:36 AM - edited 15-06-2021 03:42 AM
I'm working from home. My router and internet connection have been working fine for the past year or so. However, like many other people who've been posting over the past few days, I'm having issues with my router randomly dropping the connection both for wired and wireless devices.
I lost the connection to my router completely yesterday and spent more than an hour with technical support. The best thing they could suggest was to change the ethenet cable for my PC even though I was saying it was both wired and wireless devices that were affected 🙂
They reset my router and told me to turn it off for half an hour.
This seemed to fix the issue but I was using my wired PC just now and the connection dropped for it and the smart speaker and then came back online again after a minute or so.
Technical support were saying there is no fault on my line. I've checked the router logs and there are entries where it is dropping the connection for no apparent reason multiple times during the day.
The issues with the router started since the end of last week probably around Thursday. I have a hard drive connected to my router and these drop outs have caused files to be corrupted as well.
Some people on here are saying it is a router firmware issue and others a network level issue on TalkTalk's end. I'd like a solution to this whatever it is. My account info is in the relevant section of this site. Can you please investigate.
This is my router and firmware info:
Model = Sagemcom Fast 5364
firmware = version SG4K10002816t
on 18-06-2021 07:02 AM
The router itself will be using V1.05t and this is the latest official firmware version.
There is a new version in the works for release a little later this year.
on 18-06-2021 06:55 AM
Thanks Carl for your feedback. I've not read good reviews about it online mainly this one:
https://rhyslolly.com/2020/12/12/talktalk-wifi-hub-black-huawei-dg8041w-review-test-and-tear-down/
but I'll test it as there doesn't seem any alternative.
Can one of the TalkTalk employees on here push the latest firmware through to the router? It's running a version from 2018.
on 15-06-2021 11:36 AM
The order has already gone through for the Huawei Hub, but this model is good, I've been using this in place of my sagemcom now for about a year with no issues.
on 15-06-2021 11:20 AM
on 15-06-2021 10:44 AM
Hi Wanderer3
The Huawei WIFI hub is on its way, please allow 24-48hrs for this to arrive.
We don't have a date at the moment for when the firmware will be available. It's still in testing at the moment.
15-06-2021 10:28 AM - edited 15-06-2021 10:38 AM
Yes I'd like the Huawei Wifi Hub. AS I mentioned in my original message techical support already ran a line test and didn't detect a fault. What is the issue? I'm not the only one having this problem and am reading different replies from your colleagues and yourself on this forum. I'm paying TalkTalk to deliver a reliable broadband service. I shouldn't be having to test different routers. When do you plan to release updated firmware for the Sagemcom Fast 5364 router?
on 15-06-2021 07:11 AM
Hi Wanderer3,
I'm sorry to hear this. I've run a test on the line which hasn't detected a fault. Would you like us to send a Huawei Wifi Hub for testing to rule this out? We would also send a router returns bag so that one of the routers can be returned.
on 15-06-2021 03:51 AM
Just to add that when the router stopped working yesterday when I phoned technical support, I wasn't able to access the router admin page prior to it being reset remotely and I wasn't able to access files connected to a hard drive connected to the router which suggests some sort of router issue. The light on the router stays white
