on 19-05-2021 05:04 PM
My router started to switch off by itself every day two weeks ago then I need to plug off the power switch and then plug it on to back it to life.
But today even I plugging it off/on I struggled hard to bring it to live and then I'm really worrying about what is happening as I work from home and really need a reliable connexion
kind regards
Diego
on 20-05-2021 01:23 PM
Router and returns bag are on the way.
on 20-05-2021 10:03 AM
Hi Michelle,
So far the router is working again.
Yes please, I really appreciate having a replacement router to test and I can return the fault one if we detected it as an issue.
kind regards
Diego
on 20-05-2021 09:16 AM
Hi Diego,
Thank you. I've run a test on the line now which hasn't detected a fault. Would you like us to send a replacement router for testing purposes to rule this out? We would also send a router returns bag so that one of the routers can be returned.
on 20-05-2021 08:56 AM
Hi all,
Just completed my profile adding personal details
Thank you.
Yes, when the router turned off by itself all the lights are gone but the router button is switched on.
Kind regards
Diego
on 20-05-2021 07:03 AM
Hi Diego,
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 19-05-2021 06:49 PM
Hi @DiegoAires,
When it is 'switching off' are all of the lights going out on the router. The staff here on the community will be able to help, if they think there is a fault with your router they will be able to arrange a replacement for you.
