Sagecom FAST 5364 eTB Connection issues
mik23pe
Message 9 of 9
It seems since last couple of months the connections seems to drop and then back on
i tried couple of things but none is working
sadly on iphone i cant find a talktalk app must b looking in wrong location
can any one please help
Cheers
mik
8 REPLIES 8
Message 1 of 9
Thanks for the update 🙂
mik23pe
Message 2 of 9
Hi Debbie
thank you for the support all well now and lots of frustration seems to be end
thank you all for prompt actions and fixes
Message 3 of 9
Hi Mik
Thank you for keeping us updated.
It would be worth splitting the SSID's and then connecting your camera to either 2ghz or 5ghz.
Split your router's SSID (wireless network name)
Message 4 of 9
Hi Debbie
Thank you for the prompt response and sending over the replacement router the connection is stable and speed is good till now
i have a wifi camera which connects fine but i noticed next morning it got disconnect from router
is this something to do with router settings
Message 5 of 9
Hi mik23pe
mik23pe
Message 6 of 9
Hi Yes pls thanks for the prompt responses
Message 7 of 9
Hi mik
I've completed a line test hasn't detected any faults.
Would you like me to send a different router for testing to see how the connection compares?
Skynet_TX
Message 8 of 9
Hi @mik23pe,
What does the light do on the router when you have these issues, if it flashes amber, then amber/white, then that indicates the router is losing connection with the internet and is having to reconnect.
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
The staff here won't be around now until Monday, but they should be able to respond to this post early next week to help.
