SamKnows whitebox disconnected
1 REPLY 1
RogerE
Wizz Kid
Back in the days before Fibre, when we felt it was a good day when we had a speed in excess of 1.5Mb, TalkTalk supplied a SamKnows whitebox. Everything was ok  - Connected HG-633 to whitebox, and then everything else to Whitebox. When Fibre finally arrived - pretty constant speed at the PCs of over 35Mb.
Recently speeds dropped to less tham 3Mb at PCs, and finally found thast by-passing the whitebox speeds returned (I also changed the HG-333 to a TP-Link router in a hope of improving WiFi, but that hasn't made any difference).
Now running ok, so I need to know what happens about the whitebox, as can't find the documentation that came with it.
Roger
Gondola
Hi @RogerE
If the Whitebox isn't working you'll find helpful information here on the SamKnows website.
If the Whitebox refuses to work or is faulty, please email SamKnows at community@samknows.com and they'll get one of their experts to investigate.
 Gondola - Volunteer 2017-2020
