Scam blocker
1 REPLY 1
I requested scam blocker to be removed so I could use VPN. It still has not been removed. How long does it take? Its been 5 hours.
Just because you are working from home, do you actually need scam protection turned off? It will not stop a VPN from connecting. Which make/model of router do you have & what VPN client are you using?
