Slow Broadband
Derwig
Message 16 of 16
 Anyone else experiencing slow speeds on the SG8 area? I’m way below my guaranteed speed and have been for about a week. If this isn’t rectified within 30 days I’m walking away from my contract. Online support chat were hopeless as usual.
15 REPLIES 15
Message 1 of 16
I'm sorry to hear this. Please can you create your own topic and we'd be happy to take a look at this for you.
rtansle2
Message 2 of 16
My Internet keeps cutting out today atleast 4 times already which is not great since I work from home. How can I stop this problem?
Message 3 of 16
Thanks for the update 🙂
Message 4 of 16
All back to normal, and actually faster than before👍🏻😄. Many thanks for your help!
Message 5 of 16
The sync speeds are low, an engineer will be required.
I'll drop you a PM to confirm some details.
Derwig
Message 6 of 16
Hi Karl,
Received the router, thank you, it has been plugged in since Friday evening. There has been no improvement in speed, I am still receiving 5-6mbps to the router.  I tested the landline with a phone, it is perfectly clear, no crackling whatsoever.
The slowdown started around Thursday 5th Aug, after we had a total loss of service for about 5 mins. I can only think that something has happened to the line either at the exchange, or somewhere between there and our house, nothing has changed at our end.
Message 7 of 16
A router is on the way to you.
Derwig
Message 8 of 16
I will be back home from tomorrow, so if you could send out a replacement router that would be great. I’ll also get hold of a landline phone to check if there is a lot of noise on the line.
Derek
Message 9 of 16
Would it be possible to post back here and we can send one for you.
Derwig
Message 10 of 16
Hi Karl,
Hi Karl
Hi Karl,
Yes that sounds like a good idea, I’m away until the end of the week, so if you can arrange for one to be sent later this week that would be perfect.
Derek
Message 11 of 16
Would you like to try another router to rule out a hardware issue ?
Derwig
Message 12 of 16
Hi Karl,
Thanks for your reply, I don’t have a home phone and have never used the landline so can’t comment on that.  All i know is that nothing has changed at home at all, and the speed to the router suddenly dropped about a week ago.
Message 13 of 16
Line tests are clear, but the sync speed is very low.  Can you confirm that there is no noise on your home phone, just a clear dial tone.
Message 14 of 16
Have done the speed test, which gives a result of “Poor” 6mbps. The  line test facility doesn’t work and comes back with “Error-Looks like there has been a technical issue” 🙄
The router is plugged directly into the broadband socket on my Openreach box, so home wiring is not the issue.
Everything was working fine up until around the 30th/31st July, we had a small outage (less than 5 minutes), and since then the speed has been around 6Mbps.
Skynet_TX
Message 15 of 16
Hi @Derwig,
Have you been experiencing any drops of connection, as repeated drops will have a knock on effect on your sync speeds.
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem (although you may need to leave the router connected at the test socket for 72+ hours before you would start to see a speed increase if this was the cause of the problem).
The TalkTalk staff on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
