02-07-2021 12:34 PM - edited 02-07-2021 12:36 PM
Have been getting very slow wifi speeds 10to 15Mbps, Wired connected laptop is getting 29Mbps but the service data shows 30Mbps to the router which is still below my 34Mbps min.
Have run all the tests as per your website, rebooted everything but still no change.
have been told by a engineer friend that is proberly a router fault?
All sugestions welcome.
on 02-07-2021 06:07 PM
Hi Acorn607
I've completed a line test which hasn't detected any faults and your line is in sync at 32.4mb.
Would you like me to send a replacement router for testing?
on 02-07-2021 03:38 PM
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
on 02-07-2021 01:03 PM
Hi Acorn607
Please can you add your name and TalkTalk landline number to your Community Profile, we can then look into this for you.
