Hi anita7,
I'm sorry to hear this and I'll take a look now. I've run a test on the line which hasn't detected a fault, however I can see that at times the SNR is dropping quite low which can affect the stability, speed and the performance of the connection.
I've optimised the connection now and the SNR has increased, please let us know how the stability compares over the next 24hrs.
Hi anita7,
Are you experiencing any problems with your telephone service, any noise on the line?
How many telephone sockets do you have? Do you have anything connected to your telephone sockets in addition to your router?
Hi Chris,
The telephone is fine.
One master socket by the door, router plugged in directly into it. Nothing else connected apart from telephone. No extensions.
Today I was disconnected since around 11am until now 7pm. The speed is very slow, about 5Mbs while I normally get 7-8Mbs.
Hi anita7,
Ok thank you for confirming this. Do you have an alternative router that you can test with? If not then please let us know and we can arrange to send a replacement router for testing purposes to rule this out.
Is the broadband dropping on wired devices or just over wifi. I'm showing the line has been connected for 1 day and 7 hrs with no physical drops.
The issue was both on wired and WiFi.
That’s right, it has been stable lately but the speed is slower than normal.
I'll optimise the line profile and see if this will increase the speed a little.
Hi anita7,
Thanks for the update. Was this a wired or wireless speed test?
Hi anita7,
Thanks for confirming. The sync speed looks consistent at the moment. Could you run a few wired speed tests using the TalkTalk Speed Tester so we can see how your speeds are looking please. What speeds were you previously receiving?
Hi anita7,
I've just reset the connection now and the sync speed has increased, please let us know if there is any improvement in speed.
Dear TalkTalk!
I have problems with the broadband. Since approximately 3 days ago, i can not load any pages in. When i run a test on the routher it says it's okay but it's not.
Attila
Same here: yesterday afternoon the connection dropped several times (internet led in router went red). Restarting the router fixed it but not for long each time.
This morning we have a green led but no website responds. (Using mobile data now) In my account I am told there is something wrong with our connection but they are too busy to attend me in a chat.
Hi anita7,
Sorry to hear this. Could I confirm, does your master socket have a test socket?
