My broadband speed is currently download 0.7 and upload 0.3 tested from supportal-test.co.uk.
I have logged this speed to my account. Service check is showing fault one minute and ok the next. I am plugged straight into router.
Can you have a look into this please?
Lesley
Hi Lesley__66,
I'm sorry to hear this. I've run a test on the line which hasn't detected a fault and the sync speed looks consistent. Just to confirm, are you running the speed tests wired or wireless?
Running tests wired all morning been around 0.7 d/l and 0.3 u/l.
Just done another since your reply and its back up at 2.7 d/l and 0.7 u/l
Lesley
Hi Lesley,
Thanks for the update. Just to confirm, when you run the speed tests do you have any other applications running at the same time?
Hi Lesley__66,
Thanks for confirming this. How have you found the speeds since your last post?
Hi Lesley__66,
I'm sorry to hear this. The sync speed looks stable and there are very few errors on the line. How does the wired speed compare?
Speed has picked up to a decent download speed now, so all ok for now thanks
Hi Lesley__66
Thanks for keeping us updated, please let us know if you do experience any further issues.
