Slow fibre 150 (again)
stuart murrell
Message 36 of 36
Hello Again.
Noticed over the past 2 weeks that speeds have crept downwards - getting 80-85mbs from a 150mbs package......Would someone be able to check my line again
Cheers
35 REPLIES 35
Message 1 of 36
Hi stuart murrell
I have arranged the engineer visit for 29/09 PM (1pm - 6pm)
Message 2 of 36
Hi Debbie - PM answered, agreed and either AM or PM is ok
Message 3 of 36
Hi Stuart
Ok no problem. I'm just sending you a Private Message to confirm some details so we can arrange an engineer visit.
Message 4 of 36
Hi Debbie - in that case then yes please with the engineer
Message 5 of 36
Hi Stuart
We can't reset DLM remotely, this has to be arranged by an engineer.
If you have tested with a different router at the test socket for 48hrs and DLM hasn't increased the speed then the next step will be an engineer visit.
Message 6 of 36
Hi - if they can get my speed back up to what it should be then yes please or is there something that is doen remotely first?
Message 7 of 36
Hi Stuart
Apologies for this.
Would you like me to arrange an Openreach engineer visit?
Message 8 of 36
Hello Chris - so saturday AM i went out and bought a microfilter to allow me to connect to the test socket. Over the past 48 hours, speeds have now reduced to 50mbs so no improvement.
Message 9 of 36
@stuart murrell wrote:
Its the principle - How would you feel if you were getting your car looked at and the garage asked you to buy a tool so you could check it yourself.............
Not sure that's a very good analogy. I think a garage would be quite happy to charge you a fortune to do a simple 2 minute job rather than tell you how you could get a cheap little tool to do it yourself.
As for the line checks, I think it is perfectly reasonable to expect the customer to do a few simple checks to help narrow down the cause of the fault. It is unfortunate you don't have a telephone to plug in to check for noise etc. on the line, but I would have thought you would have some microfilters lying about. As others have said, most of us have accumulated several of the things over the years. I'm surprised there weren't any in the box with the router.
Message 10 of 36
@stuart murrell I have always received at least one, sometimes two microfilters with every router I have ever had, I have accumulated dozens over the years, do you not have any knocking about somewhere? I wouldn't take my car into a garage to pay for something I know I can check for myself.  🙂
martswain
Message 11 of 36
@stuart murrell if you are unable to isolate your internal setup by connecting to the test socket and borrowing a phone to check the line, then getting the correct engineer sent to address the issue could take even longer.
However, if you wish to stick to your principles then staff will be back on Monday to advise where to go next.
Suggest you familiarise yourself with the article below.
https://community.talktalk.co.uk/t5/Articles/Engineer-charges/ta-p/2207291
Message 12 of 36
Message 13 of 36
By all means insist on an engineer. If they come round and find no issues at the test socket that will cost you £65. Or buy a microfilter.
Message 14 of 36
Hi - i am not going to go out and buy a microfilter to allow me to test talk talk equipment. Call me old fashioned but could an engineer just come round and fix it rather than rely on the cutomer
martswain
Message 15 of 36
To use the test socket you need to connect a microfilter, however whether a standard microfilter will work with g.fast Fibre 150 is another matter.....
PS. @stuart murrell , having done a bit of research it would seem that a standard microfilter works with all over the phone line services, might be worth a punt.
Message 16 of 36
Hi - this might sound stupid and that a customer is forced to start unplugging stuff he knows nothing about but when i detach the face plate, the plug is an entierly different one from the one that goes in the faceplate so i am unable to do this - speeds have now dropped to 60mbs now........
Message 17 of 36
OK thanks. it will take DLM at least 48 hours to respond to any improvement by moving you to a faster profile
Message 18 of 36
ok - i will let you know what the score is
Message 19 of 36
Yes, the test socket is under the faceplate
Message 20 of 36
you mean take the front of the socket off and plug it in?
