Slow uplink speed
Robot5
Chat Champion
Hi Michelle
many thanks for doing that, I will check it over the next two days.
Thanks again.
Robot5
Chat Champion
Hi Chris
I have been checking the BB speeds after optimisation, the router is still connected direct to the test socket on the master point.
before on 25_4_2019 the router stats were ....
Broadband Information
DSL synchronization status:
Up
Connection status:
Showtime
Upstream line rate (kbit/s):
507
Downstream line rate (kbit/s):
2504
Maximum upstream rate (kbit/s):
624
Maximum downstream rate (kbit/s):
2940
Upstream noise safety coefficient (dB):
9.3
Downstream noise safety coefficient (dB):
6.7
Upstream interleave depth:
8
Downstream interleave depth:
32
Line standard:
ADSL_G.dmt.bis
Upstream line attenuation (dB):
36.4
Downstream line attenuation (dB):
54.6
Upstream output power (dBm):
12.6
Downstream output power (dBm):
16.9
Channel type:
Interleaved
Today 1_5_2019 they are....
Up
Connection status:
Showtime
683
1785
672
2276
5.3
7.9
4
64
Line standard:
ADSL_G.dmt.bis
36.4
55.8
12.6
17.7
Channel type:
Interleaved
The UPlink speed now is similar and ok, and seems to be better than the max possible !!, but the DOWNlink speed was 2.5Mbps and is now 1.8Mbps, around 30% slower since optimisation.
Things are getting really slow now. and the Talktalk speed checker reports it should be better.
What ever has happened here Chris ?
Clearly the link was better overall on 25_4_2019, what do you suggest to remedy it please?
many thanks
Hi Robot5,
The problem is the error count, it's been very high for over 24 hours. Could you reboot the router and then run a couple more speed tests - please let us know how you get on
Robot5
Chat Champion
Hi Chris
Ok, I have now re-booted the router, I will check the results and report back later.
As it is connected to the test socket, I assume these errors are on the BT Line or DSALM end.
Many thanks
Hi Robot5,
How are you getting on? 🙂
Robot5
Chat Champion
Hi Michelle
Well I am getting on ok, but my broadband is getting worse.
Last week I was getting 0.25Mbps for the UPlink, that has now returned to normal, 0.5Mbps or better, but the DOWNlink is now dire.
It has gone from 2.5Mbps last week to now only 1.5Mbps. the talktalk speed checker says something is wrong...
25_4-2019
Up
Connection status:
Showtime
507
2504
624
2940
9.3
6.7
8
32
Line standard:
ADSL_G.dmt.bis
36.4
54.6
12.6
16.9
Channel type:
Interleaved
2_5_2019 after optimization.
Up
Connection status:
Showtime
683
1536
688
2776
7
11.5
4
32
Line standard:
ADSL_G.dmt.bis
37.7
56
12.6
13.9
Channel type:
Interleaved
Chris told me yesterday  this was due to lots of errors in the 24Hr period.
Is this still the same over the last 24Hr period today ?
When I look at my Router internet log it shows nil errors, but it seems to have re-booted around 03:00 this morning !!
Perhaps you can investigate for me  and advise what to do next ?
I can see from the results that the DOWN link power keeps changing why is this ?
The router is still connected direct to the test socket, as it has been since Monday.
Many thanks
Hi Robot5
I've checked the connection stats and I can see a high number of errors showing on the line. The SNR is also varying.
Have you recently tested with a different router, filter and cable?
Is the landline service working ok when making calls? (any noise)
Robot5
Chat Champion
Hi Debbie
Thank you for your reply.
The router is the same router as installed last week, the filter was fitted on Monday direct to the test socket as requested by Chris and the router has remained connected to it since then.
The landline  service is working ok, no noises on line.
Where are you seeing the errors please, below is the 633 router stats.
Internet router stats
Interface  Received Sent BytePacket Error Discarded BytePacket  error Discarded
Other_R_0_65
0
0
0
0
1992
39
0
0
INTERNET_TR069_R_0_38
93641036
100940
0
0
12456961
73851
0
0
I agree the SNR is changing, but so is the DOWNlink power from the exch DSLAM ?
That would surly cause the SNR to change ? Any idea why that is happening Debbie ?
Many thanks.
Robot5
Chat Champion
Hi Debbie
Any updates on this problem please ?
Many thanks
Hi Robot5
The errors are showing on the line, I can see this on our side (our systems)
I can raise this over to our Network Team. Do you have a phone connected at the moment? It may be worth removing the phone or testing with a different phone to see if this helps.
Robot5
Chat Champion
Hi Debbie
There is a phone connected to the microfilter, which is connected to the test socket.
I think I can find another microfilter to try ?
If I disconnect the phone I won't be able to receive any calls.
Many thanks
Robot5
Chat Champion
Hi Debbie
I have replaced the  microfilter on the test socket, perhaps you can see if this changes the errors now.
Many thanks
Hi Robot5
Do you have a different phone that you can test with?
If the errors are still present with the new microfilter then I will pass this over to our Network Team.
Hi Robot5
I will check the connection stats again this afternoon, this will allow DLM time to monitor the connection.
Robot5
Chat Champion
Hi Debbie
Thank you for your reply, I will come back and look at the speed this afternoon as well.
I can connect another phone at the microfilter, but as it will not be cordless I don't want it to stay on for a long while, as all my other sockets have been disconnected since Monday, and it is getting a pain only having one phone in the house for all this week.
Many thanks
Hi Robot5
There are still errors showing on the line. Have you connected the other phone?
Robot5
Chat Champion
Hi Debbie
I have  just this minute connected the another phone in place of the one that was connected to the microfilter on the test socket.
Please let me know if there are still errors ?
Many thanks
Hi Robot5
Thank you, I will check this again in a couple of hours (to allow DLM time to monitor the connection)
Hi Robot5
The connection stats haven't updated as yet so I'm unable to see if the errors have reduced. I will continue to check this.
