Slow uplink speed
OCE_Karl
I have run a few intrusive tests on the line and also reset the port and optimised DLM.  See if performance is any better over next 24hrs.  If the errors are present after this then the only option is for an engineer visit.
Robot5
Whizz Kid
Hi Karl
Thank you for your reply.
It is gd to know that you were working on the line and the breaks were due to that fact.
I have lost count how many times the DLM has been optimised in the last 2 months, but it does not seem to really help.
5 years ago I was getting 3.5Mbps DOWNlink on this line, now on a gd day it barely makes 2.3Mbps.
Here is the proof.
System Up Time 00:25:03
Port
Status
TxPkts
RxPkts
Collisions
Tx B/s
Rx B/s
Up Time
WAN
PPPoA
8045
10068
0
809
7826
00:23:12
LAN1
Link down
LAN2
Link down
LAN3
Link down
LAN4
Link down
WLAN
54M
42170
46222
0
14769
5479
00:24:23
ADSL Link
Downstream
Upstream
Link Rate
3517 Kbps
583 Kbps
Line Attenuation
54.5 dB
34.6 dB
Noise Margin
6.1 dB
7.2 dB
9-2-2013
Router was Netgear then.
I will report back tomorrow.
Many thanks.
OCE_Karl
No Problem 🙂
Can I just check that a different router has also been tested, just to rule out a hardware issue before we look at an engineer.
Robot5
Whizz Kid
Hi Karl
Yes the current router is one TalkTalk sent me about 3 months ago, it is a Huawei HG633.
It is connected currently direct to the master test socket via microfilter.
Are you seeing errors on the line still ?
Thank you.
Robot5
Whizz Kid
Hi Karl
On the subject of hardware. Has anyone at TalkTalk checked the TalkTalk DSLAM in the local exchange, i.e. swop the card or move the circuit onto another card to eliminate a possible TalkTalk hardware fault causing this issue please ?
Thank you
Robot5
Whizz Kid
Hi Karl
I have checked the router stats today and the DOWNlink speed is 2.2 Mbps, DLM made a profile change during the night.
If you review the thread of this topic, it started with a vy poor UPlink speed, two faults were found and that speed is now stable, however, the result of this is that the DOWNlink speed is poorer than it was before the repair work by BT Openreach, and a long way below what has been achievable in previous years..
Thank you
OCE_Karl
Not seeing any issues at the port remotely and we see other users off the same card.
There were errors on the line.  too early to tell if the errors are still present following the DLM change overnight, until we allow time for the collection of diagnostics.
As to moving the line to another port or card, this would be the decision of an engineer on site, if they were detecting any port issues.
Robot5
Whizz Kid
Hi Karl
Checked today, no profile changes overnight by DLM, still same speed,DOWNlink  stuck at 2.2Mbps.
What do your diagnostics show now Karl ?
Something that keeps changing is the DOWNlink and UPlink loss, is this some thing you would expect to see ?
Any more ideas please ?
Thank you.
OCE_Karl
Error count has reduced now, and only seeing 1 errored second every few hours overnight.
The DLM profile has been set to 2560 (2.5mb) & 512 (0.5mb) up.
Line is in sync at 2.2mb down and 5.07mb up.
With little to no errors showing now, and the profile set correctly, the line speed is within expected values, so this would not warrant an engineer visit unless the error count increases over the next few days.
Robot5
Whizz Kid
Hi Karl
The UPlink is 0.507Mbps, which is par with the target 0.512Mbps, the DOWNlink is only 2.2Mbps, that is way below the 2.5Mbs of the target. Around 15% low.
Last week OCE Chris said
"Your line profile isn't limiting your speed to 2.2Mbps and SNR should be 6db so could you reboot your router and we'll see if the sync speed improves and your router resyncs back on target SNR (6db)
Chris"
I did and It only synced to 2.2Mbps.
Then Chris said
"The target SNR is 6db and profile cap is 2.56Mbps so not sure why router is syncing at 2.2Mbps with SNR of 8db - is your router currently connected to your test socket?
Chris"
 It was and still is, so you see it is not only me who believes that it is not correct.
I think the errors are low because DLM is keeping down the speed, thus masking the true problem Karl...
What do you think ?
And why does the line loss keep varying ? On a long line a change of only 2dB makes a massive difference to the DOWNlink speed.
Thank you.
OCE_Michelle
Hi Robot5,
The errored seconds have increased slightly, however it has not lowered the speed. One of the line tests is detecting a potential fault towards to the property. I can see from your thread that the router is connected at the test socket and that you've also tested with a different router, cables and microfilter.
Is the voice service still ok at this moment? Would you like us to raise this over to our Network Team for further investigation?
Robot5
Whizz Kid
Hi Michelle
Yes the voice service seems to be working ok.
Please raise the problem with the team next week.
There will not be any technical person to help here until Thursday next week.
Thank you.
OCE_Debbie
Hi Robot5
Please can you post back on this thread on Wednesday, we can then raise this over to our Network Team.
Robot5
Whizz Kid
Hi Michelle
I see there has been no profiles changes by DLM for over 6 days.
Attached the router stats of today and last time it was good  this year.
There is a large difference in the line loss, could it be this is what is causing the low DOWNlink speed now ?
DSL synchronization status:
Up
Connection status:
Showtime
Upstream line rate (kbit/s):
507
Downstream line rate (kbit/s):
2115
Maximum upstream rate (kbit/s):
712
Maximum downstream rate (kbit/s):
2516
Upstream noise safety coefficient (dB):
11.1
Downstream noise safety coefficient (dB):
7.6
Upstream interleave depth:
8
Downstream interleave depth:
16
Line standard:
ADSL_G.dmt.bis
Upstream line attenuation (dB):
46.5
Downstream line attenuation (dB):
56.6
Upstream output power (dBm):
12.6
Downstream output power (dBm):
18
Channel type:
Interleaved
18/07/2019
Up
Connection status:
Showtime
507
2504
624
2940
9.3
6.7
8
32
Line standard:
ADSL_G.dmt.bis
36.4
54.6
12.6
16.9
Channel type:
Interleaved
25_4_2019
Please let me know what you are progressing with the network team.
Thank you.
OCE_Debbie
Hi Robot5
The connection has remained stable for just over 6 days. I have reset the data port and optimised the connection but the sync speed has remained the same.
Can I just check if the router is still at the test socket? I will then ask our Network Team to take a look at the speed.
Robot5
Whizz Kid
Hi Debbie
I just noticed you do a router reset at 08:40.
And as you say the speed is still only 2.1Mbps after the reset.
Yes the router and one phone are connected to the test socket and have been for some time.
Thank you.
OCE_Debbie
Hi Robot5
Thank you. I've passed this over to our Network Team and I will post back shortly.
OCE_Debbie
Hi Robot5
The next step will be to arrange an Openreach engineer visit.
Robot5
Whizz Kid
Hi Debbie
The Downlink speed is now 1.9Mbps. And it is slow to even access this forum.
Up
Connection status:
Showtime
507
1927
688
2476
10.5
9.9
8
96
Line standard:
ADSL_G.dmt.bis
46.1
56.8
12.6
17.9
Channel type:
Interleaved
20/7/2019
UPlink line loss increased by 10dB, DOWNlink increased by 2dB.
Any idea what is causing this and reducing the speed ?
Any further progress please ?
Thank you.
OCE_Debbie
Hi Robot5
Apologies for the delay.
I have passed your availability over to our Network Team and I will post back on this thread to confirm the date and time of this visit.
