Smart tv connection problems
1 REPLY 1
Since my smart TV did an update, it will not connect to my router. It shows it there but won’t connect?
Visitors to my house also cannot connect to the internet. It is showing there on their phones but not giving them an option to connect.
Please help!!
Which make/model/firmware version of router do you have? Are any devices able to connect to it wirelessly? Have you tried a factory reset using the pinhole?
