Solid red light on hub
Michael19701
Message 7 of 7
Been like this all night
service centre no goid
need this fixed for work tomorrow
resetting router no help whatsoever
6 REPLIES 6
Message 1 of 7
Hi Michael19701
I've completed a line test which hasn't detected any faults and your line is in sync at 39mb.
What speed are you receiving when running a speed test?
Michael19701
Message 2 of 7
came back on Friday morning but very slow
now it’s away again
Message 3 of 7
Hi Michael19701
How are things this morning ?
Can you check the home phone number on your 'Community Profile' , I'm not finding a service with that number.
Skynet_TX
Message 4 of 7
Ok, if you are lucky this might just be an issue out on the Openreach network (or some network maintenance) that gets corrected overnight, so could be working ok in the morning, but if not, the TalkTalk staff will be able to help.
Message 5 of 7
Thanks. I’ve updated my profile
i work from home and now going to lose wages as I’m sure they won’t have this fixed by 7:30 am
yes on the hub one light solid amber
Skynet_TX
Message 6 of 7
Hi @Michael19701,
If you have a hub that has one single LED, then if it is solid amber that means the router is physically connected ok, but is unable to log into the TalkTalk network.
If the Service Centre line test is not indicating any issues then the staff here would need to take a look.
Then they will hopefully be able to respond to this post tomorrow. You may get faster support from the live chat or calling customer services on 0345 172 0088 during opening hours.
If your master phone socket has a test socket then you could try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem, this is not likely to help if you have a solid amber light, but you could try it just to eliminate that as a possibility if you wanted to.
