Some devices can't connect to the Wifi
nawazyarkhan
Message 2 of 2
I have got a Wifi/router device (SG4K100130) that is malfunctioning for last few days and we have got trouble connecting the mobile phones, making whatsapp calls however, notebooks are ok to connect. Also, my ring bell which was working fine and now it is not able to connect to wifi. Nothing in terms of device location/line has changed!
Please help me troubleshoot this issue
1 REPLY 1
Message 1 of 2
This is probably down to WiFi interference, rather than a router fault. The level of interference can change at any time.
Do you have any wired connections & if so, how do they perform?
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5364 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
