Speed from router to device is low : 17MBps
mswstephanie
Message 2 of 2
I have one more talktalk router.
Does it help to improve my connection in another room that is a bit far from the talktalk router?
How to do so?
1 REPLY 1
Message 1 of 2
Hi mswstephanie
Do you mean connect 2 routers? Which router are you currently using? (make and model)
