Speeds not fixing?
Ivoke
Message 10 of 10
So an engineer came to my house and said there is a bridge tap and said he fixed it and we should see our speeds going up to our guaranteed speeds over the next few days but its been over a week and i reset the router and there hasnt been a change at all, is this normal and if so how long would i have to wait.
9 REPLIES 9
Message 1 of 10
Hi Ivoke,
Thanks for confirming. Could you try one more 30 minutes router down please as the next step will be to test with a different router.
Message 2 of 10
wired
Message 3 of 10
Hi Ivoke,
Ok thanks for trying this. Are you running the speed tests wired or wireless?
Message 4 of 10
so i did it for im pretty sure 30 minutes and there is no difference im pretty sure it was a full 30 mins but idk for sure
Message 5 of 10
Hi Ivoke
Please can you power down the router again for a full 30 minutes and then run another speed test?
Message 6 of 10
i will try this
Message 7 of 10
I was getting the practically the same speeds
Message 8 of 10
Hi Ivoke
I've checked the connection stats and your line is in sync at 50.6mb.
What speed are you receiving when running a speed test? What speed were you previously receiving?
Skynet_TX
Message 9 of 10
Hi @Ivoke ,
Have you tried switching the router off for over 30 minutes, then when you switch it back on it will start a new 'session', this can sometimes help it reconnect at a better speed after a problem has been fixed.
If that does not help, the staff here should respond to this post within a day or two to offer more assistance.
