Super Router slow speed
Ruari22
Message 5 of 5
Just had a TALKTALK super router sent out to us  so iv swapped it over with the old one and now my Internet is super slow or non existent  with speeds of 3-4 mbps
4 REPLIES 4
Message 1 of 5
Hi Ruari22
Please can you add your name and TalkTalk landline number to your Community Profile, we can then look into this for you.
Message 2 of 5
Yes, but what speed is quoted by the router when you log into it?
Ruari22
Message 3 of 5
Its a Huawei HG636  TALKTALK super router
The guaranteed minimum download speed is supposed to be 30 mbps bit it shows no more than 3 or 4 mbps and there's no Ethernet cables connected
Message 4 of 5
What make/model is the new router & if you log into it, what speed does it show recorded for the internet connection?
What is your guaranteed minimum download speed quoted by TalkTalk?
Do you have any wired (Ethernet) devices connected to the router & if so are they as slow as the wireless ones?
