System reset due to kernel panic
laurencec
Message 4 of 4
I have one of your EchoLife DG8041W Home Gateway routers which I got back in July as a replacement by Roamler for my old one (which worked fine).
It's been rebooting frequently, on the logs the error is "System reset due to kernel panic"
It's running Software Version v1.05t and reading this forum it looks like v1.06t resolves it?
Can you please arrange to either upgrade my firmware remotely, or send me the file so I can upgrade my router to see if it fixes it?
3 REPLIES 3
Message 1 of 4
Hi Laurence
Apologies for this.
I've made a change the the firmware. Please can you retest and let us know how the connection compares.
Message 2 of 4
Hi @Skynet_TX ,
Thank you for responding so quickly.
I've done as you've suggested and hopefully will hear more tomorrow.
Again, I appreciate the help.
Kind Regards,
Laurence
Skynet_TX
Message 3 of 4
Hi @laurencec,
You can't update the firmware yourself, it has to be done remotely by TalkTalk. v1.06t will indeed resolve this issue for you.
