on 12-10-2020 06:38 PM
Hi, why is playback tv cutting out? & also, my internet has gone really slow lately. I'd appreciate any help. Thanx
on 29-10-2020 09:22 AM
OK, No Problem 🙂
report back when you can.
on 29-10-2020 09:12 AM
It turned up last night.......aren't Yodel slow!!
I won't be able to try this until the weekend, due to work commitments.
Fingers crossed
on 29-10-2020 08:59 AM
Tracking shows router delivered yesterday, do you have this now.
on 28-10-2020 10:54 AM
Hi Debbie
We still haven't received the replacement router??
Thanx
Justine
on 21-10-2020 10:06 AM
Hi JNk6298
As the line tests are clear then we would be unable to pass this straight to a line engineer. If a fault was detected then we could pass this to Openreach.
I have ordered a replacement router for testing, please allow 24-48hrs for this to arrive. Let us know how the connection compares with this router.
on 21-10-2020 09:38 AM
Hi Debbie,
The last time we had this type of issue a BT engineer came to the area & "did something" to the main box in the street.
But, we will try a new router if you think that will help.
Thanx again
Justine
on 21-10-2020 08:47 AM
Hi Justine
Would you like me to send a replacement router for testing to rule out any possible router faults?
on 21-10-2020 08:19 AM
Hi. As I explained earlier, our village is on lockdown & we can not go to others houses, therefore we can't get another phone to try.
Thanx
Justine
on 21-10-2020 06:24 AM
Hi JNk6298
Would it be possible to test with a different phone directly at the test socket, with the router removed from the line to see if the noise is still present in this set up?
on 19-10-2020 10:43 AM
The line is still a bit crackly.
The TV is connected wirelessly - still freezes during playback.
The internet at times is a bit slow.
Unsure of internet speeds
Thanx
on 19-10-2020 09:50 AM
Hi Justine,
Ok, thanks for confirming. I've re-run the line test now which is still clear and the connection looks stable and the sync speed also looks consistent. Just to confirm, is the crackle still present at the moment? Is it only the TV which is experiencing issues? How is the TV connected, wired or wireless?
What speeds were you previously receiving?
on 19-10-2020 09:28 AM
Hi Michelle,
Same issues.
Unfortunately we are unable to get a landline phone from a neighbour to test our line, due to Covid local restrictions.
Thanx
Justine
on 19-10-2020 08:21 AM
Hi JNk6298,
How are you getting on?
on 15-10-2020 03:02 PM
Ok
I'll see if I can get hold of another phone.
Still don't understand why playback on BBC keeps cutting out if the lines are ok??
on 15-10-2020 02:49 PM
If you do not have access to another handset, you could ask a friend or neighbour to test your handset in their socket to make sure it is ok.
If we send an engineer for a crackly line, and the line is fine and it's the handset thats at fault, you would incur a call out charge, so just trying to make sure this does not happen.
on 15-10-2020 02:40 PM
Hi Karl,
Unfortunately I don't have another handset, we never use the landline.
on 15-10-2020 02:32 PM
All line tests are clear.
Can you unplug everything out of the phone socket and make sure you test an alternative or known working phone handset directly at the master socket or 'Test Socket' if you have one, so we can proceed towards an engineer for you.
on 14-10-2020 12:10 PM
I've done all the tests & they say no faults, but our landline is very crackly.
All devices are connected wirelessly.
12-10-2020 09:10 PM - edited 12-10-2020 09:14 PM
Hi @JNk6298 ,
Are your devices connected 'wired' or 'wireless' ?
It would be worth going to the Service Centre to do a test on your phone line, this will indicate if there is currently a fault on your line. You can also access this from the ‘My Account’ site.
The TalkTalk staff on this community will also be able to help, they will hopefully be able to respond to this post within a day or two.
