TalkTalk router DG8041W-2.T5 connection issues with Samsung M7 speaker
1 REPLY 1
Hi, I’ve just changed my router from an Apple AirPort Extreme to a TalkTalk router (DG8041W-2.T5). My Samsung M7 speaker will subsequently fail on the MultiRoom WiFi set up point. Once the speakers WiFi signal is gained by my device the MultiRoom app won’t let me progress to the next point. If I connect an Ethernet cable from the TalkTalk router to the speaker it will be recognised and allow me to control it via WiFi but only whilst the Ethernet cable is in place.
I have tried resetting the speaker, resetting the router and used the MultiRoom app on various devices. If I reconnect my previous Apple Extreme router it will set up over WiFi ok. There’s clearly a parameter setting on the router that needs adjusting however I don’t know where to start. Could anyone please help? Many thanks.
note: I’ve contacted Samsung but progressed beyond the scope of the chat help.
