Unable to connect to company VPN using TalkTalk Router
3 REPLIES 3
I am creating a new post as requested.
I am the customer from this thread: https://community.talktalk.co.uk/t5/Fibre-Broadband/Unable-to-use-Direct-Access-with-Huawei-HG633-Ro...
Please help.
Quoted:
Unable to use Direct Access with Huawei HG633 Router
Good afternoon,
I work in IT Support for the local Authority and we use DirectAccess.
One of our customers, a local Councillor, is having the same trouble as described in this link:
https://community.talktalk.co.uk/t5/Fibre-Broadband/Direct-access-doesn-t-work/td-p/2368269
He is using the Huawei HG633 Router with firmware version h.1.01
I understand that the resolution is to swap out his router, could you confirm how we would go about doing this please? We've already tried calling in twice and using the live chat.
We've already tried replacing his laptop and have been out to troubleshoot at his home with additional devices, all are having intermittent connection issues.
our Direct Accessserver is working fine as no other users are having this trouble
If you can ask the user to post on here, we can talk direct with him, take some details and if required swap out the router.
We will also be able to look at the router remotely to make sure it is running the correct firmware.
Hello Karl,
Thanks, I am the user. Please let me know what you need.
Hi John
Your connection looks ok, no issues showing.  The router is running the latest firmware V2.00T.
The current router is over 3 years old so I'll swap this out for a different model.  This should arrive within the next 24-48hrs.
Let me know if direct access works with this new model.
