Upgraded to Fibre 65 - no change in performance :-(
TheBood
Message 6 of 6
I renewed my contract just over a couple of weeks ago.  The chap offered me an upgrade from 35 to 65.  I told him that I wasn't sure I could get 65 in my area, but he assured me I could.  In the back of mind I wasn't convinced, but went for it.
I've kept an eye on things and there's no change 😞  I still get the same speeds, 30MB average max.  Looking at the DSL log of my Asus router, the Max KBPS speeds haven't changed.  So I tried plugging in the TalkTalk Fast 5634 router, and still no change.
I was told, I could always downgrade, but I have only a couple of days, before I'm locked in.
Does Fibre 65 really deliver more speed?
Simon
5 REPLIES 5
Message 1 of 6
Hi Simon
From looking at the predicted speed range I don't think the speed will increase any further, sorry about this.
If you contact our Loyalty Team using Live Chat then they can remove the speed boost for you.
Message 2 of 6
Hi Debbie
I have been with TalkTalk 15years. Ever since fibre broadband has been available we have had 30mb, bar the odd glitch.  That's with no speed boost.
I was offered fibre 65.  I asked the chap are you sure we can get that? He said yes. I was sceptical, but thought why not give it a go.
I have seen no increase in the max kbps rate for download or upload. It's the same.
I even reverted to using your router, but that's the same too. I do not use your router, as it only has limited lan controls and configuration options.
So in short, I'm paying more for what I already had.  It's as though the fibre 65 has not been enabled.
Simon
Simon
Message 3 of 6
Hi TheBood
Thanks for confirming your details.
I've checked and the predicted speed range for your line is showing between 65.4 and 42.8mb, and with a guaranteed minimum speed of 32.2mb.
Were you only receiving 30mb when you added the speed boost?
Message 4 of 6
Hi TheBood
I can see that your line is in sync at 33.5mb.
I'm just sending you a Private Message to confirm some details so we can check the predicted speed range for your line.
Gliwmaeden2
Message 5 of 6
Speak to Chat about this today, @TheBood .
Links from here, after 9am:
https://community.talktalk.co.uk/t5/Articles/Our-update-on-Coronavirus/ta-p/2468300
Staff take around 2 days to catch up with the backlog from the weekend, so they may not reach this in time.
