VPN Connection - not connecting for Work
4 REPLIES 4
As I am now working from home due to COVID, my workplace requires me to connect to a VPN so that I can access files on the work server.
Unfortunately, our IT team have tried everything, but I cannot connect to the VPN and was told that the internet is likely interfering. I have tested the same laptop (and Different) on my mobile Data and it works fine, so it not an issue with my laptop.
please could you let me know how to fix this problem
Joe
Joe
Hi @JoeW0611 which router do you have and which VPN is it?
your post has been flagged for assistance and you should hear soon.
You are using a Dlink 3782 running v1.08t firmware.  There was an issue with this specific firmware version, but rather than update it, I will get a different model router to you that will work with VPN services.
Brilliant thank you very much
Joe
Hi Joe,
Please let us know how you get on 🙂
