VPN Connection not working
7 REPLIES 7
I have been using a Network Connect vpn for a few years to connect to my work.
I have just changed my PC from Win7 to Win10 and the new company vpn (windows) connects but drops out after a while and keeps doing so each time I reconnect. I spent a good while yesterday chatting with TT who wanted to sell me superfast fibre and then said VPN is not supported.
I am loathe to upgrade if I still wouldn't be able to connect to my work. I tried my PC on my sons SKY connection and it worked fine and it was tested on BT before being shipped to me.
I don't want to change provider if the issue can be fixed on the current setup that I have.
If anyone has any hints on the url I need to connect to the router I will be grateful as well - is it http or https and which suffix eg /login
I managed to connect yesterday after trying several variations but for the life of me I cant remember which one was successfull
Colin
Hi Pilote741
I'm unable to connect to your router, apologies for this. Which router are you using? (make and model)
Hi Debbie
The router is a D-Link DSL 3680
Colin
Colin
Hi Colin
I think we should send a HG633 for testing, would you like me to arrange this?
Thanks Debbie - that would be great.
Colin
Colin
Hi Colin
The replacement HG633 router is on its way, please allow 24-48hrs for this to arrive.
Thank you so much for organising the router. It has been installed since lunchtime and I have been connected to the vpn for the afternoon so looks good.
Colin
That's great news, glad the VPN connection is working for you.
