VPN Connectivity issues with WiFi Hub
Wilson2405
Message 12 of 12
I can't connect to my work's VPN with the WiFi Hub. I've read that other people had similar problems. Can you please help on how to either change settings on the router to allow VPN or send a router that does support VPN as this will disrupt my work significantly in the forthcoming weeks with Coronavirus.
My work connect via Connect2.
The message I get is 'Could not connect to Secure Gateway because the certificate is invalid or not trusted by the client system. Click OK to exit NC and Sign in to Secure Gateway again. If problem persists, please contact your administrator.'
I'm connecting from  Windows 7.
11 REPLIES 11
Message 1 of 12
Hi Wilson2405
How are you getting on?
Message 2 of 12
Hi Wilson2405,
Just checking to see if the replacement router has arrived and if the VPN connection is now ok?
Message 3 of 12
Hi Wilson2405
The replacement router is on its way. There will be no charge for this.
Once you connect the new router your family will just need to connect their devices again to this router (using the wireless password)
Please allow 24-48hrs for this to arrive.
Message 4 of 12
That would be great thanks. Would this be free? and how does it impact the rest of my family/devices using Wi-Fi?
Message 5 of 12
Hi Wilson2405,
Ok thanks. Would you like us to send a replacement router (different make and model) for testing?
Message 6 of 12
I'm not sure what that means exactly, but I have to use iPass and connect2 along with an RSA key fob. Is that what you need?
Message 7 of 12
Hi Wilson2405,
Thank you. I've checked and your router does have the latest version of firmware which should work ok with VPN. What VPN Client are you using? Would you like us to send a different make and model of router for testing?
Message 8 of 12
Hi, yes I spoke to the first, they said its to do with your side.
Message 9 of 12
Hi Michelle,
I cannot connect wired or wireless.
I have updated my details.
Message 10 of 12
Hi Wilson2405,
Sorry to hear this. Are you unable to connect both wired and wireless?
  • Name
  • Telephone number
  • Alternative contact number
StephenF
Community Manager
Message 11 of 12
Hey, one of the team will be along shortly to offer advice, can i ask have you spoken to your works IT department for advice in the first instance? I ask because the WiFi hub does support VPN and does work with many different VPN clients and often it can be a configuration issue.
Stephen, Community Manager
