I am unable to connect to PANGP Virtual Ethernet Adapter Global Protect via my TalkTalk WiFi.
I have firmware v1.10t, and have tried splitting the SSID and using Ethernet connection. I do not have Scam Protection enabled.
I also have areas in my apartment where the WiFi does not 'reach', despite it being less than 350 sq ft with no walls.
I can help further with your Wi-Fi reception problem, but I think it best to get the VPN issue sorted first.
Your line looks ok, no issues showing.
Would you like me to dispatch a different model of router for testing ?
Hi gemmaereed
