VPN Issues
15 REPLIES 15
blaen102
I can't connect to my work's VPN through my Talktalk internet.
I've got a Dlink DSL 3782 and trying to connect to a Juniper VPN. I phoned TT customer services but didn't get a very helpful reply other than 'we provide a dynamic IP address that doesn't support VPNs, thanks for calling, bye'
Looks like a lot of people have got help though this forum. Is anyone able to advise how best to proceed please.
Thanks,
That is rubbish, the problem is that the current firmware on the 3782 blocks VPNs. I will ask one of TalkTalk's OCEs to pick your thread up and they will probably offer to replace the router with one that does support VPNs.
The forum is not real-time 24/7 support, so depending on how busy they are & how many are working at any one time, this can take 24 - 48 hrs (excluding weekends & Bank Holidays). Alternatively, you can call the call centre or use online chat. The posts are responded to in time/date order, oldest first. So the fewer entries you make on your thread now, the sooner they will pick it up.
Otherwise, TT will not be able to tie up your forum username to your broadband account. Only you & TalkTalk have visibility of your details.
Hi blaen102
I can send a HG633 router which should resolve this issue. Would you like me to arrange this?
blaen102
Thanks both.
Yes please if you can send a replacement router that would be great.
Many Thanks,
Simon
Hi Simon
The HG633 router is on its way, please allow 24-48hrs for this to arrive.
blaen102
Hi Debbie,
Thanks for sending the new router. I plugged it in and it works fine, but I'm still having exactly the same issues. Is there anything else you can recommend trying?
Thanks,
Simon
Hi Simon
Is the HG633 router currently connected to the line? Please can you factory reset your router using the pin hole reset for ten seconds, I can then try and connect to your router.
blaen102
Hi Debbie,
The new router is connected and I've just reset it.
Thanks,
Simon
Hi Simon
Thank you 🙂
I've updated the router firmware version, please let us know how the connection compares following this.
blaen102
Thanks Debbie,
Still having the same issues I'm afraid
Hi Simon
What happens when you try to connect?
blaen102
Hi Debbie,
It connects as usual and the status screen shows connection (above), but when I try to access the network drives it return the error below. I've tried on other connections and it works no problem.
blaen102
Hi Debbie,
I've managed to get it working, for now at least.
After trying lots of different things, I changed the DNS to 8.8.8.8 and 8.8.4.4 and it's done the trick. Thanks to others on the forum for sharing their solutions.
Simon
Hi Simon
Pippaa
Hi, I am having the same problem. I need a VPN with work and rang talk talk who told me there was nothing they could....
Hi Pippaa,
I'm sorry to hear this. Please can you create your own thread and we can look into this further for you.
