VPN Issues
geoffcole
Sightseer
Message 13 of 13
I am one of many having issues connecting to my work VPN after 18 months working successfully it has just stopped working. I have a work colleague with the same issue who is on TalkTalk. All other colleagues who use other service providers have no issue. I can connect via mobile hotspot and have tried all the suggested fix/setting changes but nothing works.
Getting very frustrating with TalkTalk tech support not helping. I have seen some in the community being offered alternative routers with some success.
How have people managed to get the new router sent to them?
12 REPLIES 12
Message 1 of 13
Just following up on the recent VPN Issue you had, to aid our Teams in their investigation of the issue affecting the Sagemcom 5364 router running Firmware V130t.
Can you let me know if you tried changing the Firewall level in the router and if this allowed the VPN to connect.
Also, when using Windows inbuilt VPN, can you let me know what setting you chose from the below image.
Karl. ​​​​​​​
Message 2 of 13
Hi AlexSpooner
If you start your own thread (new message), wed love to help.
Weve found that posting in someone elses conversation makes it harder to follow when looking for an answer.
Its easier and quicker if we can chat with you in a single thread, if you start your own thread, that will keep our community organised and help others with a similar problem.
Check your home phone number or account number are also added to your Community Profile as that will really help us to find your details quicker.
AlexSpooner
Visitor
Message 3 of 13
Hi, I am also experiencing issues with a VPN not connecting, which also began a few weeks ago. Please could I also have a new router sent out?
Many thanks
Message 4 of 13
Hi geoffcole
I'm so glad to hear this.
Yes please can you return the Sagemcom router using the pre paid returns bag.
Message 5 of 13
New router received and has worked first time. VPN connected instantly! Thanks for arranging the replacement router. Should I send the old one back using the enclosed returns label?
Message 6 of 13
I've ordered the router, it should be with you within a couple of days but please allow up to 5 working days for delivery
Message 7 of 13
Hi Chris,
If that could be arranged I would be grateful!
Message 8 of 13
OK thanks, would you like us to send a different make and model of router to test with?
Message 9 of 13
It is the Sagemcom standard issue from TalkTalk, Device Version: FAST 5364-3. T8
Was working fine until last week!
Message 10 of 13
Hi geoffcole,
Could you just confirm which router you have please
geoffcole
Sightseer
Message 11 of 13
Thanks for your reply. I did a factory reset while on the phone to tech support last week but this didn't work. I am using windows 10 and automatic VPN settings
Message 12 of 13
Hi geoffcole
Can I just check, which VPN client are you using?
Have you tried factory resetting the router using the pin hole reset for ten seconds?
