VPN Issues
AlexSpooner
Message 11 of 11
Hi, Similar to problems others have been having, I've been working from home successfully for 18 months with no issues with my VPN, but a few weeks ago it just stopped working. I see from other threads that a new router solved the issue. Would it be possible, please, to have one sent out to me?
Many thanks,
Alex
10 REPLIES 10
Message 1 of 11
Hi Alex
Thanks for the Private Message.
Message 2 of 11
Hi Alex
Please can you send me a Private Message to confirm the name on the account, I can then send the replacement router.
Message 3 of 11
Hi Debbie, yes please that would be great!
Thanks,
Alex
Message 4 of 11
Hi Alex
Ok, would you like me to send a different make and model of router for testing?
Message 5 of 11
Hi Debbie, I've just reset the router, and still get the message "A connection to the remote computer could not be established, so the port used for this connection was closed".
I'm afraid I have no idea what a VPN client is, or where to find out what it is.
Message 6 of 11
Hi Alex
Thank you.
I can see that your router updated to the latest firmware version.
Can just check which VPN client you are using?
Have you factory reset the router using the pin hole reset for ten seconds?
AlexSpooner
Message 7 of 11
Hi Debbie - all done - sorry for the delay - had to dig the number out!
Message 8 of 11
Hi AlexSpooner
Please can you also add your TalkTalk landline number to your Community Profile.
AlexSpooner
Message 9 of 11
Hi Michelle,
Should be all done!
Message 10 of 11
Hi Alex,
  • Name
  • Telephone number
  • Alternative contact number
