VPN NOT WORKING WITH MY TALKTALK ROUTER
gizem
Message 11 of 11
I can't acces my aws rds service which I must connect to through openvpn. There are no errors on our Amazon AWS VPN our side and OpenVPN connects with no errors.
 have noticed this thread below, which has an identical router, identical VPN and software. I also get the same issue when trying to connect to any AWS hosted endpoint.
https://community.talktalk.co.uk/t5/Fibre-Broadband/Same-old-Not-able-to-connect-to-my-work-VPN-usin...
I tried all of my knowledge  but I couldn't resolve. Also, I can connect my hotspot connection
From the above post, getting a different TalkTalk router solved the problem.
Could you please help me
GizFey
10 REPLIES 10
Message 1 of 11
Hi gizem
Thank you.
gizem
Message 2 of 11
Hi, I have just  added my information through settings wizard.
GizFey
Message 3 of 11
Hi gizem
Please can you add your name and TalkTalk landline number to your Community Profile. I can then send you a different make and model of router for testing.
gizem
Message 4 of 11
Thank you for your help Keith. You're really helpfull.
GizFey
Message 5 of 11
OK, I will ask TalkTalk to consider changing this for a different router (that thread didn't seem to say what the replacement was). This won't now be until at least tomorrow.
gizem
Message 6 of 11
In the follow link show there is problem with fast 5364.  It is not completely with vpn but with openvpn
https://community.talktalk.co.uk/t5/Fibre/Same-old-Not-able-to-connect-to-my-work-VPN-using-FAST-536...
GizFey
gizem
Message 7 of 11
SG4K10002816t
GizFey
Message 8 of 11
There are no known VPN issues with this router. What firmware version is it running?
gizem
Message 9 of 11
Hi Keith,  thank you for responding. I have fast 5364 router
GizFey
Message 10 of 11
Which make/model of TalkTalk router do you have?
