VPN again
CaptainJack
Message 12 of 12
Wow I am really stuck!
Basically I am trying to connect to a VPN then connect to some NHS software using a smart card.
The VPN says it is connected but once I put the smart card and enter the PIN it goes through the initial start and then stops when it says remote server cannot be connected.
I have a DSL-3782 and no it doesnt work. Just bought a cheap tp-link modem/router and nope exactly the same.
I have seen some posts that new routers work but which one? Tried almost everything. Help!
11 REPLIES 11
jaja06
Message 1 of 12
how can I stop someone connected to my router to use VPN? It makes my connection really slower. he said hes not connected because I always disconnect his gadget at night. but when I do check this one appears on diagnosis. there is a hophostaddress.
jaja06
Message 2 of 12
jaja06
Message 3 of 12
  1.
jaja06
Message 4 of 12
how can i stopsomeone conbectiong
Message 5 of 12
Hi earley-day,
Can you start your own thread and complete your Community Profile and we'll be happy to look into this for you
Message 6 of 12
Hi Karl,
I have the very same issue.
I have the 3782 router which allows my VPN to connect but then does not allow my RDS to connect which is very frustrating. Are there settings within the 3782 that can be changed to allow access?
Earley-Days
Message 7 of 12
Hi CaptainJack,
Thanks for the update 🙂
Message 8 of 12
Thanks - sorted!
Message 9 of 12
Guys, you are stars. Thank you for your help and quick response. Truly appreciated and fingers crossed this resolves everything. I will keep you informed.
CaptainJack
Message 10 of 12
Hi CaptainJack
I'll get a HG633 router out to you for testing.  This should work with your VPN.
Message 11 of 12
Hi @CaptainJack
The current firmware of the 3782 blocks VPNs. I will ask one of TalkTalk's OCEs to pick your thread up and they will probably offer you the HG633, which does work with VPNs.
