Once logged into the router you should select INTERNET from the Top menu then INTERNET CONNECTION from the side menu.
Under Internet DSL, click Edit and scroll down.
You may need to tick the static DNS option.
you should then be able to enter the details.
ok followed your instructions and had to tick the box you mentioned to then allow the details to be entered. I will run the speed test with and without vpn in the morning and let you know how it goes and if i see any improvement!! thanks
No Problem. The speed will always be a little slower over VPN as this is going through a work server.
