VPN issues
1 REPLY 1
I am having issues connecting to my work computer using DrayTek smart VPN. Setup has been completed fine and everything looks fine and ready to go from IT however I'm still having issues connecting.
I have tried splitting my SSID's as suggested in another post but it made no difference.
Hi aeon900
I've checked and your router has the latest firmware and should work ok with VPN.
Please can you try factory resetting the router using the pin hole reset for 10 seconds, and then testing this again?
