VPN not working
Margaret23
Message 3 of 3
I posted the post below on 27 February 2019
I am having problems connecting into my office from home. I use sonic wall VPN. The problem started when I got a new router from TalkTalk (DSL 3782). I note from previous posts that other users of this router are having the same problem. Can someone arrange to send me a router that allows me to connect into my office using VPN. I understand that another router (HG633) will solve the problem. Thanks in advance.
I received a reply and email telling me to include my telephone number in my profile so that the engineers could pick up the problem. I did that on 28 February 2019 but have heard nothing further......What do I do now?
Message 1 of 3
Hi Margaret23
I'm unable to connect to your router, apologies for this.
Please can you factory reset your router using the pin hole reset for ten seconds, I can then try and update your router firmware.
Message 2 of 3
There is new firmware for this router that fixes the VPN issues. I have asked one of TalkTalk's OCEs to pick your thread up and upgrade it for you.
