VPN problem
deusart
Message 15 of 15
I need to work on a Polish server, but I'm rejected all the time, I have a problem with connections.
I have been told by IT support that it has to be that my broadband supplier blocks it in some way... I cant remember technical terms.
Can you please help me and tel me what to do?
I have unblocked TeamView in MyAccount but I can't do nothing with VPN...
When I go to hotspot from EE it worked fine. So I'm sure as well that it's my Fibre...
please help
Arkadiusz Stefaniak
14 REPLIES 14
Message 1 of 15
Hi @daveburrows67
I will take a look at your topic now.
Message 2 of 15
@daveburrows67 Start your own topic and the team will be happy to help,
Message 3 of 15
You should have the router in 24-48hrs.
Message 4 of 15
Thank You Karl,
So I'm expecting a new Router, yes? When do you think it should be delivered?
many thanks
Arkadiusz Stefaniak
daveburrows67
Message 5 of 15
HI I have exactly the same problem, can log into work vpn using my mobile hotspot  and at various offices, but at home on Talk talk cannot connect... I need help too please!!!
Message 6 of 15
I'm not seeing any issues with the connection, all usual tests are clear.
I've a different model router on the way so we can rule out any hardware issue.
Message 7 of 15
Yes it is and it looks like it has. 🙂
I have just reported the fact that it is not clear on the site.
Message 8 of 15
Hi Debbie,
Is it custom profile phone_number ??? I did update it now.
Arkadiusz Stefaniak
Message 9 of 15
Judging by the lack of an icon against your avatar it doesn't look like this has been done, click here and make sure your full landline number is entered where indicated.
Message 10 of 15
Hi deusart
I can't see the landline number in your Community Profile, please can you re add this information? (click save changes button at the bottom of the page)
Message 11 of 15
I did update my profile yesterday, Can you help me with this now? Please?
Arkadiusz Stefaniak
Message 12 of 15
Hi deusart
Please can you add your name and TalkTalk landline number to your Community Profile, we can then look into this further.
deusart
Message 13 of 15
The router is Huawei HG633
VPN Software is VyprVPN
I will try to update my profile soon.
I have been struggling a lot... I have been used my own mobile data.
Arkadiusz Stefaniak
Skynet_TX
Message 14 of 15
Hi @deusart,
What model of router do you have, and what VPN software are you trying to use.
