Very slow speeds recently
Worldgeek
Message 5 of 5
In the last few of weeks our upload speed has slowed down very much
Previously we had sufficient bandwidth for video conferencing.
Zoom has become unusable which is a great shame for my elderly parents.
I ran all the TalkTalk status tests but no solution offered other than upgrading to fibre or paying for a new router.
Has our connection been capped for some reason?
Thanks for any help.
4 REPLIES 4
Message 1 of 5
I've reset the port and profile and the speed should have increased for you now.
Skynet_TX
Message 2 of 5
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service that might be slowing your connection. You can also access this from the ‘My Account’ site.
The TalkTalk staff on this community will also be able to help, they will hopefully be able to respond to this post tomorrow. They will be able to check your router and your connection to see if there are any issues limiting your speeds.
Message 3 of 5
Thanks @Skynet_TX,
Previously our bandwidth was sufficient for video chat and now it isn't.
Speed as follows:
Downstream Line Rate :4095 kbps
Upstream Line Rate :251 kbps
Skynet_TX
Message 4 of 5
Hi @Worldgeek,
If you log into your router what speed are you seeing for your upstream sync speed . If you run a speed test (ideally from both a wired and wireless device so that you can compare), how close are the upstream speed test results to the sync speed shown on your router.
If you are on ADSL then the maximum upload speed possible is 1mbps, if you were on Fibre 35 that that can allow speeds of up to 10mbps. So upload speeds are quite limited for ADSL connections.
