on 19-01-2021 02:49 PM
Router - FAST5364 3.00
SW - SG4K10002816t
Hi, I noticed a speed drop of around 6Mb recently on the router but assumed this is due to high traffic in recent times.
However more notably, Ive found the 5Ghz WiFi is enabled but the status always says DISABLED.
Can this be checked from TT side?
Many thanks
TX
on 27-01-2021 01:02 PM
Hi Sephriem
Thank you 🙂
on 26-01-2021 09:45 AM
on 26-01-2021 08:40 AM
Hi Sephriem
Thanks for the Private Message.
on 26-01-2021 07:23 AM
Hi Sephriem
Apologies for the delay.
Please can you send me a Private Message to confirm the name on the account, I can then send the replacement router.
on 23-01-2021 01:58 PM
Hi @Debbie-TalkTalk thanks for getting back again.
I think I may need to test with a new router.
I reset from the back of the device but it still states down for the 5Ghz channels.
Toggling on and off still doesn't do anything :(.
Many thanks again.
on 22-01-2021 04:37 PM
Hi Sephriem
Thank you, if you still experience this issue then please let us know and we can send a replacement router.
on 22-01-2021 04:04 PM
Hi @Debbie-TalkTalk, thanks for getting back to me.
i think i have only factory reset it once previously, but nothing anytime recently.
I will do a reset over night and check it again in the morning and get back to you.
Many thanks
on 21-01-2021 08:43 AM
Hi Sephriem
Can I just check, have you tried factory resetting the router using the pin hole reset for ten seconds?
on 19-01-2021 09:43 PM
Thanks for the input @KeithFrench @
Good to hear that others have had to give the feedback, helps TT out.
Will keep my eyes on the reply
on 19-01-2021 02:56 PM
There has been a few routers displaying this fault. I have asked one of TalkTalk's OCEs to pick your thread up and investigate it for you.
