WIFI NOT CONNECTING ON CERTAIN DEVICES ONLY
Markmcd1976
Message 4 of 4
I've just tried your useless live chat function and wasted an hour -can someone please help?
I have three devices as of this morning that can't connect to your router.
A Samsung smart TV
An Amazon Fire
A BT WIfi extender
all were fine yesterday and a HP laptop and two iphones can still connect.
The other devices cant's see the Talk Talk router when we do a scan.
Can you please help?
3 REPLIES 3
Message 1 of 4
Just glad this worked.  If it starts to happen again, then the router could be starting to fail and may need to be replaced.
Markmcd1976
Message 2 of 4
Thanks Karl - that seems to have worked. Any reason why they would have all dropped off?
Also your LiveChat didn't recommend this  - it would have saved a wasted hour earlier.
Thanks for your assistance!
Message 3 of 4
Hi Mark,
Have you tried a pin reset of the router - hold a pin or paperclip in the reset hole at the back for 10 seconds and this will fully reset the router.
Do other devices connect ok ? Is it only these 3 ?  Have you tried separating the SSID's (wifi names)
