WIFI strength is too poor
Hi my WiFi connection is poor.
Working from home is proving difficult as cannot open large documents and files I need for work. Streaming tv shows is very slow and can often pause.
how can this be improved?
To enable me to help you, please can you specify the make/model of TalkTalk router that you are using?
Hi Alemq1091
  • Name
  • Telephone number
  • Alternative contact number
