on 14-02-2020 12:21 PM
I am running 2 PCs both plugged directly into a HG633 router and neither have the necessary s/ware for wifi. Can anyone suggest a good USB wifi dongle that I can purchase.
Also if and when I start to use wifi other than passwords what other things do I have to consider?
Any help will be appreciated.
on 15-02-2020 06:50 PM
I always recommend alfa to anyone looking for a good quality wireless adapter, here is a link, reasonably priced, with all the bells and whistles for the future .
https://www.amazon.co.uk/dp/B00MX57AO4/ref=psdc_430581031_t4_B00VEEBOPG
on 14-02-2020 04:30 PM
If this is just to tide you over there are plenty of cheap options on the likes of Amazon, look for a reputable make e.g. TP-Link.
@KeithFrench wrote:
... if you want to go to macOS, you are on your own.
Not sure why you say that @KeithFrench? Apple Macs have had wireless AC cards installed since 2013. As will any modern PC of course.
on 14-02-2020 04:19 PM
You should really look for one that supports 802.11ac, anything else will be out of date. I would also recommend looking for one that supports what is called AC1200 or greater, you may not currently need a link rate between the adapter & router of 867Mbps, but again it helps to future proof the purchase. Next make sure it supports 5GHz channels 52 to about 104 as some only support 36 - 48 and they can be getting too congested now.
Obviously it must have Windows 7 & 10 drivers, if you want to go to macOS, you are on your own.
on 14-02-2020 03:50 PM
Basically I'll pay what is necessary. My Download speed is between 30 and 40 Mb. I'm running Windows 7 might be upgraded to Windows 10 or an Apple Mac
on 14-02-2020 01:07 PM
That very much depends on what you want to pay, how fast a connection you want between it & the router and your operating system.
