WiFi Hub wired connection
Message 4 of 4
I work from home and the wired connection to my work PC keeps dropping.  When I log into my hub it has a question mark next to wired connection but I can’t figure out why or where to look to see what the issue is.
3 REPLIES 3
Message 1 of 4
We have another connection at home, which I have switch to on a temp basis and doesn’t have any issues.  The problems have only started since we switched to TalkTalk.  As it’s affecting my ability to work from home I’m not impressed.
Message 2 of 4
Ethernet cable is a week old, tried a different port with no effect and my pc cannot find any issues in troubleshooting.
martswain
Message 3 of 4
1. Change the ethernet cable.
2. Try a different ethernet port on your router.
3. Run the network troubleshooter on your computer.
